I propose adding the "Feature Blend" capability to ArcGIS Online, similar to what is available in ArcGIS Pro. This would allow for more visually appealing and informative maps, particularly for overlapping polygons: https://www.youtube.com/watch?v=BdoLUsj3pEI
Isabelle Breton
Hi Isabelle,
Thanks for your idea.
As a work around for now, you may be able to achieve the same effect as you see in the video using blend modes for layers:
1. Create 2 copies of the polygon layer with different fiilters
2. Set the blend mode for the top layer to Multiply.
