Hello
I have this code which sort values base on buffer 1320 feet and return First values. I want to return all values inside the buffer not just one. is it any way I can do this?
// If the feature doesn't have a geometry, return null
if (IsEmpty(Geometry($feature))) { return null }
// Get the bus stops layer
// To customize, replace the layer name below
var busStops = FeatureSetByName($map,"RTD Active Bus Stops")
// Buffer the current location and intersect with the bus stops
var bufferedLocation = Buffer($feature, 1000, 'feet')
var candidateStops = Intersects(busStops, bufferedLocation)
// Calculate the distance between the bus stops and the current location
// Store the feature and distance as a dictionary and push it into an array
var featuresWithDistances = []
for (var f in candidateStops) {
Push(featuresWithDistances,
'distance': Distance($feature, f, 'feet'),
'feature': f
// Sort the candidate bus stops by distance using a custom function
function sortByDistance(a, b) {
return a['distance'] - b['distance']
var sorted = Sort(featuresWithDistances, sortByDistance)
// Get the closest bus stop
var closestFeatureWithDistance = First(sorted)
// If there was no bus stop, return null
if (IsEmpty(closestFeatureWithDistance)) { return null }
// Return the bus stop name attribute value
// To customize, replace the field name "STOPNAME" below
return `${closestFeatureWithDistance['feature']['STOPNAME']}`
