Map in a minute: Map Coastal Property Loss using ArcGIS Online and ArcGIS Living Atlas
518
08-14-2024 07:53 PM
BernSzukalski
Esri Frequent Contributor
4 0 518
While coastal communities make up only 10% of the U.S. land mass, nearly 40% of the population can be found in coastal communities. An estimated $1 trillion worth of property is located within 700 feet of the coast and by 2050, it is estimated that up to $106 billion worth of coastal property will likely be impacted if current trends continue.
Using World Imagery Wayback and Regrid parcel boundaries from Living Atlas, along with Map Viewer and ArcGIS Instant Apps, you can quickly and effectively view coastal change and property loss over time.
mimce-33
For more information, see Map in a minute: Map coastal property loss using ArcGIS Online and ArcGIS Living Atlas by @BernSzukalski. The blog article covers using Wayback, using Map Viewer to add Regrid parcels, and leverages the Media Map Instant App to use its swipe tool for viewing change over time.
Visit the ArcGIS Online blogs to learn about what's new and for more blog articles that help you get the most out of ArcGIS Online and ArcGIS Instant Apps.
Contributors
About the Author
Esri technical evangelist and product advocate. On a good day I'm making a map. On a great day I'm on one. https://www.linkedin.com/in/bernszukalski/ bszukalski@esri.com
