Find out what a user has been doing in your organization
5912
8
03-15-2019 04:06 PM
KellyGerrow
Esri Alum
3 8 5,912
The History endpoint of the REST API is a great tool to dig into information about events occurring in your organization. Although you easily download a comprehensive CSV of events as an administrator in ArcGIS Online, the REST API, provides the option to customize the data returned and to ask more specific questions. For an example of how to use the history CSV, check out this blog: https://www.esri.com/arcgis-blog/products/arcgis-/administration/exploring-the-organization-activity...
For this blog I am going to outline the query and results about a specific member of my ArcGIS Online organization.
Scenario: It’s time for Karate_Kelly’s year end review. She wants to prove to her boss that she has been busy creating and managing content in the organization. Using the History API, She’ll query all of the events that she has initiated in 2018.
Detective Steps:
  1. Formulate the Query
Url: https:/webapps.maps.arcgis.com/sharing/rest/portals/self/history?
Parameters:
all=true – returns events for all members in the organization
start=0 – Starts at the first record
num=10000 – largest amount of events returned (requires csv format)
f=csv – Returns result in a csv
sortOrder=asc – information output in ascending order
token = “6hVsODGfBpk5X_hGc0MOrnxmddIk4bL4hP8FyOAxM0QxL3VEw86iTdB” – admin token required
fromDate =2018-01-01 – start of date range
actors= Karate_KElly – events to be returned (Note, usernames are case sensitive, so if you hit a key by accident while creating your username, check the casing just to be sure... #Karate_KEllyIsNotAMistake)
Sample Url constructed:
https://webapps.maps.arcgis.com/sharing/rest/portals/self/history?all=true&start=0&actors=Karate_KElly&sortOrder=asc&fromDate=2018-01-01&num=10000&f=csv&token=Qian2inO2Cqf0tsljaLVJC5YbmjpQvg-CQ565QE75vesENzX5Yorf40K4ai_7fHn8
  1. Submit the request and view the resulting CSV
  2. Perform analysis or use pivot tables to provide insight into actions
ActionCount of Actions
Add412
Add Users7
Create12
Delete104
Failed Login15
Login192
Remove Users1
Share252
Update1448
Tracking my events by Month:
JanFebMarchAprilMayJuneJulyAugSeptOctNovDec
# of Actions10185727427614829149129101261445
Test: When did I go on Summer vacation last year?
This is a neat way to look at your actions and your organizations members actions over time.
*Note. Only available in ArcGIS Online
https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2019/03/16/generate-a-token?sr=se...
8 Comments
GregoryLund2
Thank you for posting.
I'm not a developer, and apologies for the stupid questions.
I am the AGOL Administrator at my University and would like to try this, but need some assistance.
Is it me, or is this what I should see at your: "1. Formulate the Query, Url: https:/webapps.maps.arcgis.com/sharing/rest/portals/self/history?" =
image of self/history
When I utilize my address: "uwt-gis-geotech" the result is the same:
is this the proper sample path?
I'm not seeing wehre the '&31' is from.
Again, thank you for posting, and apologies for the silly questions.
Regards,
Greg
KellyGerrow
Esri Alum
Hi Greg,
My bad, there was a typo in the sample url. I have fixed it up now (no 31&) needed, but be warned the token isn't valid so you won't be able to successfully load the sample url.
For your url try,
https://uwt-gis-geotech.maps.arcgis.com/sharing/rest/portals/self/history?all=true&start=0&actors=<enterusername>&sortOrder=asc&fromDate=2018-01-01&num=10000&f=csv&token=<add your admin token>
Using the URL should result in a csv being downloaded automatically. Let me know if that gets you up and running or if you have more questions.
I'll post another blog about how to get the token, just in case it comes up.
Kelly
JTessier
Do you have plans to include this as part of On-premise ArcGIS Enterprise?  If so at what version?
Thanks!
J
Jason Worrel
AndrewRudin1
Is there a way to obtain this admin token programmatically via the REST API?  Is it different then the token obtained by the/sharing/rest/oauth2/authorize endpoint or the /sharing/rest/generateToken endpoint?
I ask because I'm trying to get an ETL tool to retrieve data from the AGOL REST API's portal_history endpoint via my federated admin account, but the authentication documentation for the API sends me in circles for this type of Portal administrative workflow where I just need to connect to the ArcGIS Online Org or Enterprise Portal and query out some details about users, items, licenses, etc.
I assume the code is as basic as two lines
1) Submit REST call containing my credentials to obtain the token
2) Submit REST call to the Portal_History endpoint containing my credentials
PhilipSacca
New Explorer
I am using Arcgis Portal on premise, when I try the history end point I get
Unable to retrieve history?
Error: 500
https://xxxxvpor01.xxxsky.lab/portal/sharing/rest/portals/self/history?token=JJGZ7vaLd3E_WSpkC_n84ho...
MaxSquires
the same message is returned from the python api for arcgis.
from arcgis.gis import GIS
gis = GIS(portal_url, "siteadmin", secret)
gis.admin.history(start_date=datetime.datetime.today())
>> 'C:\\Users\\<user>\\AppData\\Local\\Temp\\history.csv'
contents of history.csv:
{"error":{"code":500, messageCode:"DB_0279", message:"Unable to retrieve history.", details:["Unable to retrieve history."]}}
frdchp2021
hi, Do you get any work around about history ?  (I got the same wonder if somebody answered this)
SoledadPons_Martinez
Occasional Explorer
Hi @KellyGerrow ,
I am working in a ArcGIS Enterprise On-Premise Portal. When I tried the /history endpoint I get the following:
{"error": {
 "code": 500,
 "messageCode": "DB_0279",
 "message": "Unable to retrieve history.",
 "details": ["Unable to retrieve history."]
 I know /history is only available for ArcGIS Online.
Could you tell us if there's an alternative tool to obtain the same within ArcGIS Enterprise?
I'm working with version 10.8.1 and I've heard about Activity Dashboard extension but I'm not sure if it could be useful as well to track users activity.
Thanks in advance,
S.
About the Author
I love interactive maps and apps on the internet! The maps and apps that customers create and share on the web, make my job awesome. I'm a Product Manager with the ArcGIS Online team in Redlands, California. I am a proud graduate from Carleton University and the COGS in Canada, with research focus' in Health Geography. Originally from Bedford, NS, Canada but have spent a lot of time in Haliburton and Ottawa, Ontario. I have a passion for the outdoors and dogs.
