ArcGIS Online tip of the week: Learn more about simple Arcade in pop-ups using Living Atlas content.
1075
10-12-2023 08:19 PM
BernSzukalski
Esri Frequent Contributor
4 0 1,075
Arcade is an expression language that is supported across ArcGIS. Arcade in pop-ups can be used in two ways; to create attribute expressions used in text elements that can be evaluated like fields, or as separate Arcade content elements that return a complete block of content. Using Arcade expressions and elements, you can take your pop-ups to the next level.
One of the best ways to learn more about Arcade in pop-ups is to examine existing examples. The ArcGIS Living Atlas Esri Federal Data collection contains many maps that have used Arcade to format and deliver expressive pop-ups. You'll find simple examples of formatting text, translating codes or acronyms into readable strings, handling text case, and much more.
Just open a map, click Pop-ups on the Settings (light) toolbar, then view the attribute expressions to view the existing expressions to learn more.
 For more information and to see more examples, see Pop-ups: Arcade essentials.
Contributors
About the Author
Esri technical evangelist and product advocate. On a good day I'm making a map. On a great day I'm on one. https://www.linkedin.com/in/bernszukalski/ bszukalski@esri.com
