I have a problem with the Jupyter Notebook embedded inside ArcGIS Pro 2.6
By going into details, when I run even a simple code as
import arcgis
from arcgis.gis import GIS
gis = GIS()
map = gis.map("Italy")it returns me a Runtime error:
RuntimeError: Unable to cast Python instance to C++ type (compile in debug mode for details)
If I try to run the same code inside a "normal" Notebook (with normal I mean a Jupyter Notebook outside of ArcGIS Pro), it works. I attached the two scenarios I previously described.
Do you have any idea to solve this weird behaviour?
Thank you
Have you tried including arcpy and os? i.e.
import arcpy,os
