I can't enable the administrative access to ArcGIS Notebook server using webadaptor
1160
02-04-2024 05:37 AM
AhmedFathy74
I have installed ArcGIS Notebook server 10.8.1 and ArcGIS web Adaptor and while I was configuring with the server, I didn't find the "Enable Administrative Access with Your Web Adaptor.
so, I can't access the server using web Adaptor.
please, if you know how I can enable that, reply with instructions.
Thanks in advance.
Ahmed
shikhar_deep
Hi @AhmedFathy74
Thanks for reaching out.
  1. Could you please share the status of the notebook server machine (using the private url) from the administrative api? which is
    https:<notebook server hostname>:11443/arcgis/admin/machines/<notebook server hostname>/status
  2. In the notebook server machine, could you please share the results of 'docker info' & 'docker version'
  3. Can you also try re-adding the web adaptor from a different browser, i.e. remove web adaptor from the notebook server site. Re-install the web adaptor with a different web adaptor context and add the same using a different browser.
David_McRitchie
Hey Ahmad
You can access the update menu for the Web Adaptor via the Server Admin menu. Navigate to https://<FQDM>/server/admin/system/webadaptors/<WebAdaptorID>/update
Here you can enable administrative access without any need for a reinstall.
Hope that helps,
David
Esri UK -Technical Support Analyst
