Network Analyst - Which type of road is used by route?
1997
8
03-02-2018 02:50 AM
MatthiasWüthrich
Hello
I solved a vehicle routing problem  for logging operations. To get to the orders, my route uses two types of roads (streets and logging tracks). The route created is a simple polyline, but I would like to know at which point the route is on logging tracks and on which on  the street. Is there a possibility that network analyst can tell me which road type is used? To ilustrate what I want, I draw this quick and dirty sketch.
Sketch
MelindaMorang
Actually, the easiest way is to run the Copy Traversed Source Features tool.  This will output feature classes that include the network edges, junctions, and turns that were used to make up the route.
JoeBorgione
I think you'll need to perform a spatial selection using the route to select the underlying features of your street data that was used to build the network.  The streets have the type info, correct?
XanderBakker
Esri Esteemed Contributor
Maybe the least difficult way could be to buffer (small distance) the road types, using a FLAT line end (Advanced license required) and then intersect the route with this buffer to get the road type into the result.
MelindaMorang
XanderBakker
Thanks for sharing MMorang-esristaff . Learning something new every day here.
JohnFix1
As an old Arc/Info user I was wondering, where is the "section" table? lol.
Thank you very much, this command is what I needed.
JaySandhu
When we were designing the route-system, some folks did not want to expose the section attribute table, but I lobbied for it to be visible as it was most useful  And then it became even more useful when we re-wrote the route/allocate products to be in Arcplot and wrote the results out to the RAT/SEC tables. Old memories!
Jay Sandhu
JohnFix1
Arcplot! Now that takes me back! "Display 1040" hahaha
MatthiasWüthrich
Thanks for all the answers. I finally did with the Copy Traversed Source Features tool, it gives me exactly the outpout I want.
