How to get the road segment IDs/ way IDs From the Route Result?
1680
12-13-2019 02:28 AM
d4001628urhen
I was looking for a way to get the routed road segment IDs from the resulting path in arcpy Python (notebook). I simply want to get the mapped road segments when we submit a set of stops. Can someone help me with that?
MelindaMorang
I'm not sure if this works in a Python notebook, but with arcpy in ArcMap or ArcGIS Pro,  you can use the Copy Traversed Source Features tool to get what you want.
d4001628urhen
Melinda Morang‌ Thank you for the response. The example there seems bit complex for me as I'm a newbie for arcgis. Can you pls share an example in ArcGis Pro for a dummy path?. That would be really helpful. Thank you agian
