How to choose one facility with "find closest facilities" script tool in model builder?
1037
11-27-2017 02:30 PM
fengchen1
I  use "find closest facilities" script tool to do network analysis and I have to use this tool in model builder. I want to choose only one point as facilities, which can be achieved when I use it just as a tool (click the point that you want to choose on the street network). But when I add this script tool in the model builder I cannot choose only one point because I should stop editing in using model builder.
Could you please tell me what should I do? Thank you so much.
Tags (1)
DanPatterson_Retired
You could use things like Select by Attribute in your workflow to select and limit the input location.  So if you have a unique identifier (ie FID or OBJECTID field).  The selection is honored for subsequent steps.
fengchen1
I solved the problem, thanks for your kind help!
