Error when adding breaks in a vehicule routing problem (invalid SQL query)
1343
05-19-2011 09:03 AM
denismatarangas
Hi I am trying to add breaks on each of the 12 routes created for a paratransit service. the solver works well, however when I try to add breaks (MaxCumulWorkTime or MaxCumulWorkTime) an error occurs (invalid SQL query). Only TimeWindows breaks are working.
I followed ArcGis instructions carefully and I don't understand why it is not working... Can someone helps?
Thank you!
NaAn
Could you please provide more details on how you added the MaxCumulWorkTime break?
A vehicle routing problem analysis layer can only be solved if all breaks are of the same type; that is, the solve process will fail if there is any combination of time-window, maximum-travel-time, and maximum-work-time breaks.
Thanks.
Anna
