Data type to be used in 'StreetName' field in source Streets for Output Directions for Route Analysis?
1270
12-17-2019 07:49 AM
HelenaBreuer
I am running route analysis with the 'Output on Solve' for directions in the route analysis tab. After running, it prompts a window stating "Invalid type for field StreetName in source Streets." In the Streets table, the field 'StreetName' has a data type 'text'.
I double checked with the tutorial posted, and the StreetName in the Streets layer has the same data type (text).
It should be noted that I am using Public Transit Time as the Time Attribute.
Is there any reason why the directions are failing to output?
JaySandhu
Is it possible that the streetname field does not have valid text data? Perhaps some rows have some invalid text strings? If it cannot be explained then have Esri tech support examine the data and determine what is going on.
Jay Sandhu
