I am running route analysis with the 'Output on Solve' for directions in the route analysis tab. After running, it prompts a window stating "Invalid type for field StreetName in source Streets." In the Streets table, the field 'StreetName' has a data type 'text'.
I double checked with the tutorial posted, and the StreetName in the Streets layer has the same data type (text).
It should be noted that I am using Public Transit Time as the Time Attribute.
Is there any reason why the directions are failing to output?
