Hello, I am trying to build a network data set for the public transit system in Allegheny County, Pennsylvania by following the steps in the "Create and use a network dataset with public transit data" tutorial (link below) and template. Everything works exactly as it is described in the tutorial except for the creation of the StopConnectors feature. For some reason, none of my stops snap to any street. All features from the GTFS to Network Dataset Transit Sources seem to have been populated correctly. I made sure to project the streets file to match all the other features in the geodatabase/feature dataset that was created. Additionally, I tried increasing the snap distance from 100 meters to 1000 meters but no change.
When I zoom in and compare matching Stops IDs to StopsOnStreets IDs found to have missing geometry in the StopConnectors table, they all seem to completely overlap one another. Most stops are reasonably close to a street as well. I'm at a bit of a loss. Any idea why I'm not getting any StopConnector geometry?
I attached the project below with the model I created to run the entire process. I tried to include the GTFS files and street centerlines but they are too big to attach. The template can be found following the link below but the issue arises before it is necessary and the template has worked without issue.
Thanks!
https://pro.arcgis.com/en/pro-app/latest/help/analysis/networks/create-and-use-a-network-dataset-with-public-transit-data.htm#
