ArcGIS 10.2 “Drive time analysis” service area problem
3841
11-30-2014 08:13 PM
robcorner
Although reasonably experienced with ArcGIS I am a bit of a newbie with Network analyst. I have a situation in which things work Ok with the tutorial data but not with mine!
I am trying to determine an 8km road distance from a set of hospitals in East Africa. I have some roads data that I can build into a network. As far as I can see there is full connectivity. If I work using detailed polygons (which is what I want) I get this.
net2
So the "service area does not go along roads A,B and C, which I would expect it to. and how on earth does it think I am going to get to Point D!!.
Using generalised polygons I get this: net2
Now I have lost the slightly anomalous point D, but the services area still does not traverse roads A and B
Any help gratefully appreciated
Rob Corner. Curtin University Western Australia
AsafBen-Ari
I assume you did not determine a "no turn" property, so it must be connectivity problems.
I would have start with building a Geometry Network, and then use the Utility Network Analyst to run the "Find disconnected features"‌.
Asaf.
deleted-user-25j2k-XonNEg
Some of the connection issues I've run in to are incorrect intersections (unaligned vertices), incorrect one-way designations and incorrect elevations.
