Batch export of turn-by-turn directions from routes generated using Calculate Travel Cost in Enterprise Portal or ArcGIS Online
256
08-26-2025 06:57 AM
Status: Open
SWATConsultingInc
It would be helpful to have the option to export turn-by-turn directions from the "launch directions" option when a route is created in either Enterprise Portal or ArcGIS Online. At this point when you launch directions, the only option a user has is to select copy/paste or print to PDF. Both of which require manual formatting afterwards. Having the turn-by-turn directions exported in a simple CSV/text file so we could incorporate them in our own mapping environment (i.e., map callouts in Pro) would save us a lot of time. We also have thousands of these written directions to compile, thousands of origin to destination pairs, I can generate routes between these pairs easily, but cannot output the turn-by-turn directions in a batch way. This functionality would be incredibly valuable to add, it would save us many hours!
