In addition to point/line/polygon barriers for a VRP or Route layer, would like to have turn restrictions/scaled costs. Turn tables are available for local networks, but not for AGOL's Route Service.
(For my study area, there is a busy highway where left turns, especially with our vehicle's trailer, are dicey. Would like to add penalties for making left turns onto this highway. Our driver's are deviating quite a bit from the computed routes to avoid these turns which leads to other problems in tracking/logging Order visits.)
Hi Dale. It seems unlikely that we'd be able to add user-facing turn restrictions into the AGOL service dataset because it would require a schema change or some entirely new concept we don't have (turn barriers?). However, we can definitely take a look at the specific intersection that's causing you problems and work with the data vendor to get it updated. Can you send us the coordinates of the intersection and maybe a screenshot of the left turn that isn't safe?
