You are not licenced to use Navigator (Android)
3916
11
12-20-2016 12:32 PM
ИванМехедов
I have two Portals. Configurations of both Portals are similar. Both have Navigator entitlements imported in (from the same entitlements file).
When logging in Navigator (Android) using the first Portal named user credentials, everything is OK.
When logging in Navigator (Android) using the second Portal named user credentials, i get a message saying that my user is not licenced to use Navigator.
The error is reproducable on any Android device (3G, WIFI) and is not reproducable on any iOS device (we can log into Navigator using both Portals from iOS devices).
So what can be the problem with it? What Portal settings should we check out?
ScottSandusky
Ivan, this is a bug in Android, and we will be fixing it within the next update of Navigator Android.
ScottSandusky
Hello Ivan,
When you license Navigator and receive a entitlements file for your Portal, it is for deployment with one Portal. Using that same entitlements file in multiple Portals would be against the licensing terms of use.
The inconsistency across iOS and Android leads me to believe something isn't right - let me/us try to reproduce and get back to you...
ScottSandusky
Ivan, For the Portal that does not work...
Does it have the setting to allows anonymous logins or not?
Is it using web-tier authentication?
ИванМехедов
Scott, the Portal which does not allow Navigator to connect, does not have an option of anonymous login set. I tried to set it and it worked!
So we cant use Navigator for Android in our organization due to this issue (anonymous login is prohibited)?
ScottSandusky
ИванМехедов
Thank you Scott
ИванМехедов
Scott, may you share the exact date of the new Navigator Android release with this bug fixed?
ScottSandusky
Ivan,
Today we have released an update to Navigator for ArcGIS on Android.  This 2.0.1 update corrects a bug that can prevent Navigator from logging into a Portal that does not allow anonymous access.
ИванМехедов
Thank you.
We've just checked - it works now.
TroyBum72
@ Scott Sandusky I believe we hit this today with 10.4.1 portal and Navigator 2.0.0 iOS.  We are curious to know if/when a 2.0.1 release for iOS might be released to correct the problem for us?  We are in the middle of a huge deployment project.  I have an open case:  01920842.  Thanks!
