Hi! If I use my own dataset to build a navigation map, each time my data gets updated I must rebuild the navigation map in ArcGIS Pro (included Address Locators) and upload it as an mmpk on AGOL, right?
If you want your Navigator users to have the most current version of your map (network dataset) - Yes. You will need to re-build it and share it using ArcGIS Pro.
