Can you do 'Contains' instead of 'Starts with' in search suggestions when configuring locator?
1662
8
01-22-2024 05:43 AM
TL2
Users are complaining they can't search on part of a name, can you customize search?
KerriRasmussen
Good morning,
I'm sorry you are having issues with your locator. I do have a couple questions for you. Are your users searching for assets (either using an ID or other attribute field) or are they searching for addresses or something else? And are you using a custom locator?
Thank you,
Kerri
TL2
Customer locator on POI only.  Using one name field for POI.
TL2
@KerriRasmussen I just wanted to confirm when searching for a POI (using a text attribute field) the search is 'starting with' and not 'contains'.  I believe this to be the case - is there a workaround to this?
KerriRasmussen
@TL2 Good afternoon. Can you tell me when the locator was created and what version of Pro you were using to create it?
TL2
3.1.3 and it was created in Dec 2023.
KerriRasmussen
@TL2I spoke with the Pro team and unfortunately, there is no contains for locators. I would recommend adding this enhancement request to the Esri ideas page: https://community.esri.com/t5/arcgis-pro-ideas/idb-p/arcgis-pro-ideas and sharing your use case.
TL2
Thanks for confirming.
KerriRasmussen
You're welcome.
