Windows host component record only memory metrics
1193
10-29-2023 10:42 AM
IrisHadarStltd
I've register windows 2012 host component in Monitor 2023.1 .
When viewing the metrics it seems that monitor only collects stats on memory and none on cpu , network or disks.
When I checked the observers the dicover appear in green but the metrics is yellow and report that the observer failed.
The user that is running the monitor service is a domain user which is also local admin on that windows host .
Does anyone knows what can i do to fix this ?
AndrewSakowicz
this is a known case since 10.8  and the resolution applies to 2023.x
IrisHadarStltd
Thank you for the prompt answer.
The link you sent is for 10.8 monitor is it the same function when using monitor 2023.1?
AndrewSakowicz
