What causes AWS ELB Log Parser to have item not running or behind schedule Sate
848
09-18-2019 12:49 PM
GaryParker
AWS System Log parser for ELB logs keeps showing error 'item not running or behind schedule'. Any ideas what would keep causing this to occur? I can normally get this to catch up by going into the ArcGIS Monitor Administrator, stopping the collection and then testing and saving again.
by Anonymous User
Not applicable
It sounds like you are running System Log Parser for ELB as a standalone tool when this problem happens.
In the past we have seen this issue if you have requested too much data (the data in the collection is too large). Try requesting data from a shorter timeline. ArcGIS Monitor executing SLP for ELP as a task usually runs fine because it is setup to run hourly (less data is being requested).
by Anonymous User
Not applicable
