Web Adaptor for ArcGIS Monitor
1144
08-31-2023 12:53 PM
murphyse
Hello,
I just finished successfully deploying ArcGIS Monitor v2023.2. The documentation in installation and system requirements was invaluable. Thank you Esri!
One thing I did not see was accessing Monitor through alternate URL/site. Is there documentation on how to apply a web adaptor or configure Windows IIS to access Monitor through a site and not the machine name and port itself?
Thank you!
DerekLaw
Esri Esteemed Contributor
Hi @murphyse,
Currently you connecting to ArcGIS Monitor through the ArcGIS Web Adaptor is not possible - but this is on our dev roadmap.
Please see this blog: Connecting to ArcGIS Monitor 2023 through IIS
Hope this helps,
lvargas
Hello @murphyse
Web Adaptor cannot register for ArcGIS Monitor (at this moment), but you can use IIS or a different web server (reverse proxy) as NGINX, tomcat etc. to forward traffic (from 443 to 30443).
Redirect from HTTP to HTTPS using the IIS URL Rewrite module
NGINX Reverse Proxy
Regards.
DerekLaw
Hi @murphyse,
Hope this helps,
