Version not updated to 2024.1
420
02-21-2025 12:55 PM
HazelRiordan
When I updated my ArcGIS Monitor from 2024.0 to 2024.1, the updated version did not reflect in ArcGIS Monitor under Administration > License.  The application clearly updated, as I can see the updates/enhancements. Has anyone else had this problem?
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi @HazelRiordan,
This is expected behavior. We don't update the ArcGIS Monitor license file for minor releases, only major releases.
FYI: You can check the release version of ArcGIS Monitor by clicking your profile in the upper right corner of the web app,
Alternatively, you could also navigate to Monitoring page > Agents and this will display the AM Agent release versions,
Hope this helps,
DerekLaw
Hi @HazelRiordan,
Hope this helps,
