Using ArcGIS Monitor to check on feature service availability
882
10-19-2022 02:55 PM
GabeWiebe2
Hi there,
I was wondering if anyone has set up ArcGIS Monitor to check on the status of a particular feature service?
We are having intermittent availability issues with hosted feature services on our server/portal and I wanted to use ArcGIS Monitor to tell me when the feature service is no longer available but I can't seem to figure out how to do that.
Thanks!
DerekLaw
Esri Esteemed Contributor
Hi @GabeWiebe2,
Currently, ArcGIS Monitor does not provide data metrics for hosted feature services. We are working with the hosted feature services Dev team to enable reporting of data metrics for these services and plan on adding support in a future ArcGIS Monitor release.
Please share any detailed user requirements you have for supporting data metrics on hosted feature services.
Hope this helps,
