Upgrade Monitor postgres from 14x to 17x
108
6
Wednesday
DavidColey
MVP Frequent Contributor
Hello - I'm at Monitor 2025.0 and will shortly go to 2025.1.  However before doing so I want to upgrade the postgres instance since it is still sitting at 14.x.
Is it possible using the following:
Upgrading PostgreSQL in Windows · GitHub
without going to 16.x first?  It wasn't clear to me if I can use the pg_upgrade command when going up more than 2+ postgres versions...
thanks-
David
CodyPatterson
MVP Regular Contributor
Hey @DavidColey
When I've upgraded in the past, it was always one version at a time, we had let ours go without update for a little long, and we had three major versions to go up on. Basically it was just the standard take backup of the instance, and then run the upgrade command, wait an hour or so to ensure everything is set, and then repeat. I think that may be the only way to do so, mostly because I've seen that there's changes each major version, and skipping may result in those changes causing errors, etc.
Cody
DavidColey
Ok thanks for the feedback @CodyPatterson.  The methods in the GIT link above reads that there should not be an issue going from 14 to 16, so that is probably what I will do.  That way I'm not trying to skip ahead 2 versions....
CodyPatterson
Hey @DavidColey
Let me know what the outcome is if you decide to do the 2 version jump, I'm very interested to know as it'd save quite a bit of time!
Cody
DavidColey
Oh I'm going to do it @CodyPatterson  and yes I'll let you know.  If it doesn't work I'll just roll back to a snap and take my medicine
DavidColey
This seems to have been successful @CodyPatterson - but I did only go from 14 to 16.  However, maybe you can help me on this:
Failed to register ArcGIS Monitor database
no pg_hba.conf entry for host "1.2.3.4", user "agm", database "agm", no encryption
So when I upgraded postgres, I lost my pg 14 conf file.
This is what my conf file looks like at postgres 16:
# TYPE DATABASE USER ADDRESS METHOD
# "local" is for Unix domain socket connections only
local all all scram-sha-256
# IPv4 local connections:
host all all 127.0.0.1/32 scram-sha-256
host agm postgres 10.140.xy.xyz/32 scram-sha-256
# IPv6 local connections:
host all all ::1/128 scram-sha-256
# Allow replication connections from localhost, by a user with the
# replication privilege.local replication all scram-sha-256
host replication all 127.0.0.1/32 scram-sha-256
host replication all ::1/128 scram-sha-256
Do you see anywhere else I should be adding or removing the entry for the agm host?
David
DavidColey
Don't worry about it @CodyPatterson - I figured it out.  The entry only goes here:
host agm agm 10.140.xy.xyz/32 scram-sha-256
We rolled back.  There are other issues going on.  Moving forward, I'll upgrade Monitor to 2025.1 first, then run the pg_upgrade
