Register Component: Oracle
419
02-17-2023 07:56 AM
DanielHerrera
Is there a preferred way to connect using the address and service name fields when registering an Oracle connection?  I have the 64-bit client working on the server, and even added the Oracle instant client - both are working fine when connecting to sqlplus.  When I try to register the Oracle component I'm getting this error:
ORA-12154: TNS:could not resolve the connect identifier specified
Daniel
George_Thompson
Esri Notable Contributor
What are you putting in your connection properties in ArcGIS?
Are you using TNS (<name>) or EZConnect (<server/SID>)?
If using TNS in the connection properties, do you have TNS configured in the client?
I would just go with the 64-bit full client and not the instant client.
--- George T.
