Problem testing EgdbDatastore Extension.
1210
06-29-2018 05:14 AM
KjellTimalm
I´m testing this extension and when I come to the execution validation part of the instruction I get an error.
Command: egdb.exe myGDB_ODBC_datastore.xml List
And getting this error: ERROR: Input string was not in a correct format.. Exiting ...
I haven´t changed anything in the xml file.
JohnGraham2
Hi Kjell,
The file myGDB_ODBC_datastore.xml contains decimal numbers in English (United States) format. Try adjusting the Regional Settings to a different Region/Language - English (United States) - and check if this solves the format error.
JohnGraham2
Hi Kjell,
KjellTimalm
Hi John,
Thank you. It solved the problem.
