Partition management job failed
1076
10-02-2023 06:28 PM
FraserHand
Hi There,
Has anyone come across this error:
I recently set the data retention to 90 days - is this related?
Thanks
Fraser
EDIT: I think this is related to https://community.esri.com/t5/arcgis-monitor-questions/partition-tables-not-created/m-p/1328147#M128...
Tags (1)
GeoJosh
Hi Fraser,
Since you have confirmed that partitions are being created as expected, you can disregard this message in the logs. We have seen some instances where this message is logged when it should not be. Also for your information, ArcGIS Monitor creates partitions for 5 days into the future.
Josh
fraserheagle
EDIT: I can see the partitions in metrics_data and component_logs and they have been created up until 2023_10_08 on both so it appears not to be the same issue as the linked post (though I'm not sure how far ahead these get created). Thanks!
GeoJosh
Hi Fraser,
Josh
FraserHand
Thanks Josh - I'll keep and eye on the partitions over the next couple of days to confirm they are being created as expected - thanks for the info 👍
