Monitor Upgrade- Extension Versions Missing
1003
11-18-2020 11:31 AM
Amanda__Huber
MVP Regular Contributor
Hello Monitor Team,
Our team is preparing to upgrade to Monitor 10.8.1 and upon reviewing the upgrade documentation we found this portion about extensions very confusing:
"If your deployment has extensions or tasks, download the latest versions from the ArcGIS Monitor gallery and refer to the PDF included with the extension for upgrade instructions."
None of these extensions listed in the gallery show version numbers on the items page or even in the pdf documentation- therefore when preparing for our upgrade it is unclear if these extensions will break because of the version difference or if they are compatible.
Please make versions more clear on either the item details page or in the PDF documentation.
MattD
by Esri Contributor
As the extensions are not officially supported products they do not follow the same release cycle as the main product. I think your best bet for the extensions would be to compare the release dates with the date of the release version, and test the functionality of the extensions before pushing out a counter necessary for production monitoring.
