Monitor 2025 with 11.4 Web Adaptor - Uninstall the 11.4 WA first?
329
06-09-2025 06:45 AM
DavidColey
MVP Frequent Contributor
Hello -
I feel like I should be unregistering and/or uninstalling the 11.4 web adaptor that is currently registered with my 2024.1 monitor deployment before I begin the Monitor 2025 Server and Agent upgrade.  But I'm not seeing guidance either way in the setup and config docs.
JakeSkinner
Esri Esteemed Contributor
Hi @DavidColey, you won't have to do it before, but you will need to uninstall 11.4 Web Adaptor and install 11.5 Web Adaptor for Monitor 2025:
https://doc.arcgis.com/en/monitor/latest/install/windows/install-and-configure-arcgis-web-adaptor-wi....
JakeSkinner
DavidColey
Thanks @JakeSkinner I went ahead and uninstalled it prior to running Monitor Server exe. Probably doesn't matter when it's done.
