I've installed Monitor 2025.0, and now my Oracle SDE observers are broken for the metrics and inventory observers. I'm connected via the SDE account, so that shouldn't be an issue. I've also unregistered one of the now broken Oracle SDE database components, and reregistered, and no dice. Here is the observer error I'm getting:
LevelTimeCode
Warning
6/26/25, 12:30:00.545 PM
E_OBSERVER_FAILURE
MessageResourceDetails
Run failed
observers:59
WITH UNFILTERED_TABLES AS ( SELECT GI.PHYSICALNAME AS "table_name", CASE WHEN GI.DEFINITION IS NULL THEN 'other' WHEN XMLQUERY('/*/ShapeType' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT) IS NULL THEN NULL WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'point') > 0 THEN 'point' WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'line') > 0 THEN 'line' WHEN INSTR(LOWER(XMLQUERY('/*/ShapeType/text()' PASSING XMLTYPE(GI.DEFINITION) RETURNING CONTENT)), 'polygon') > 0 THEN 'polygon' ELSE 'other' END AS "geometry_type", CASE WHEN BITAND(TR.OBJECT_FLAGS, POWER(2, 3)) <> 0 THEN 'traditional' WHEN BITAND(TR.OBJECT_FLAGS, POWER(2, 25)) <> 0 |
Hi @Royce_Simpson,
Can you please open an issue with Esri Tech Support so they can help you investigate further?
Hi @Royce_Simpson,
I wonder if your issue is related to the item identified in this thread,
ArcGIS Monitor 2025.0 Oracle Database Observer Fails
Hope this helps,
