I've recently installed Monitor 2024.1 on a new server. I had previously been running 2023.* on a different machine. I've successfully registered 4 agents on 4 separate machines in our Enterprise. Monitor Server is recognizing all the components including 323 service components. Likewise, all the infrastructure telemetry seems to be coming in correctly. What I am not seeing is any data on the ArcGIS-side including data on requests received, request response time, ArcSOC instances used, etc. Logs indicate various codes including "E_AUTH_TOKEN_EXPIRED" and "E_AUTH_INVALID" but I haven't been able to track down the issue. Any suggestions?
