Migrate / Save Monitor Analysis for use in another installation
412
07-19-2024 06:37 AM
SGTomlins
Good Day,
Spent some time getting Monitor to report on the items I need.  Utilized many of the ESRI blog examples in doing so.  My question is can that all be saved and used in another installation of Monitor? Export/Import and then be able to edit the particulars for the new environment?
I have followed the backup/restore procedures as published and had success restoring to the same computer. I would like to save the work already accomplished for other environments without re-creating them all.
Thank you
-Steve
SGTomlins
Thank you..  I understand the development process.  Monitor is a fun tool and I look forward to the continued improvements.
-Steve
DerekLaw
Esri Esteemed Contributor
Hi @SGTomlins,
> Analysis views ... can that all be saved and used in another installation of Monitor? Export/Import and then be able to edit the particulars for the new environment?
Unfortunately, the export/import of configured elements in Analysis views is not currently possible in ArcGIS Monitor. Sorry. This is on the Dev roadmap and planned to be part of the Monitor 2024.1 release.
Hope this helps,
SGTomlins
-Steve
AndrewSakowicz
@SGTomlins , as a temporary workaround for 2023 only, perhaps you could consider steps described in Solved: Analysis from ESRI Developer Summit 2024 - Esri Community
