Linux host component registration
1415
04-08-2023 01:12 AM
arahman_mdmajid
We are trying to register a Linux component with the host OS already upgraded to RHEL 8.6 version based on the recommendation.
After inserting the required fields and registering the component, we get the following error.
Cannot read properties of null (reading 'trim')
Kindly advise
Abdur Rahman
GIS Developer
Tags (3)
GeoJosh
Hi Abdur. Thanks for bringing this issue to our attention. I'm going to follow up with you via private message to get some more information about your system.
Josh
TomGiles2
Hi Josh
I am receiving this error when connecting to a linux CentOS variant container (turnkey linux) (may or may not be related).  Using username/password, not ssh. Works when connecting to ubuntu VMs.
Can you shed any light on the situation from your investigation 04-10?
Using ArcGIS Monitor 2023.1.
Thanks
Tom
arahman_mdmajid
Hi @GeoJosh
We upgraded our ArcGIS Monitor to 2023.1 and initially when we tried to register our Linux host we got the following error
ssh -G <domain-name-of-our-Linux-host>
'ssh' is not recognized as an internal or external command,
operable program or batch file.
Then we moved on and added other components and then tried again after refreshing the page and all. Then we got the following error
Abdur Rahman
GIS Developer
