How to configure IIS Webadaptor component in ArcGIS Monitor 2023?
2757
8
02-14-2023 05:17 AM
VarunKakkar
How to configure the IIS Webadaptor component in ArcGIS Monitor 2023?
Any help would be appreciated!
Thanks!
GeoJosh
Web adaptors cannot be registered as components in the current release of ArcGIS Monitor. This is a feature that is being considered for a future release.
Josh
ReeseFacendini
Esri Alum
The ArcGIS Web Adaptor does not support connections with ArcGIS Monitor. A reverse proxy can be implemented in IIS to forward traffic from 443 to 30443.
FraserHand
Hi Reese,
I've set up IIS with ARR 3.0 and Url Rewrite and have a simple rule to rewrite traffic from 443 to 30443 - have you got a sample / example IIS rewrite rule I could compare with to check I haven't missed any config?
ReeseFacendini
Esri Alum
This is the rule that I have in place to forward traffic.
FraserHand
Thanks for that - appreciate it! Was very similar to what I have which is reassuring. Thanks for sharing.
Fraser
GeoJosh
Josh
VarunKakkar
Hello @GeoJosh ,
Thank you for your response! Just wanted to ask one additional point the IIS extension was available in 10.8.1, which allowed all usage to be studied for Hosted layers. Attached is the screenshot :
and Will the extension will be supported and will similar metrics are expected in the next release?
GeoJosh
Thank you for this feedback. Web adaptor monitoring is not planned to be included in the next release of Monitor but it will certainly be considered for a future version.
Josh
VarunKakkar
Thanks, @GeoJosh! Looking forward to these features in the next release.
Varun
