How can i monitor arcgis data store health or hosted feature request on arcgis monitor 2023.1
2699
5
05-15-2023 06:00 AM
EdnaKanazawa
I would like to know how I can monitor arcgis data store health or the response of hosted feature resource because there is in same case the hosted feature stop to responding and a I need restart the arcgis service service.
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi @EdnaKanazawa,
ArcGIS Monitor does not currently supporting registering the ArcGIS Data Store as a component.
As for getting data metrics on hosted feature services, please review the discussion in this thread,
Unable to see published hosted feature layer in ArcGIS Monitor 2023
Hope this helps,
AndrewSakowicz
Although as  @DerekLaw  pointed out, data store is not a supported component, users can potentially monitor availability using combination of host, db components and server logs.  Note, ArcGIS data store does not have a direct "health check" call.
mhudson
Curious if adding the data store is going to be a supported workflow in the future? If so, any idea as to when?
Matt
DerekLaw
Hi @mhudson
This enhancement is under consideration. We don't have a timeline on when this will be enabled.
Hope this helps,
DerekLaw
Hi @EdnaKanazawa,
FYI: The ArcGIS Monitor 2023.3 release, now collects metrics for hosted feature services for ArcGIS Enterprise 11.1 and later releases. Please review the blog,
ArcGIS Monitor 2023.3 Now Available!!
Hope this helps,
