High Availability - Portal for ArcGIS
177
06-29-2025 09:25 PM
KikSiops
I recently upgraded our ArcGIS Monitor from 2023.2 to 2024.1. I have successfully registered the components of HA but only one server for each component.
For example: I registered the all the ArcGIS Server Components (Hosting, GIS and Image Server) which are Active-Active (2 servers for each component).
But it is only showing 3 under ArcGIS Server. I found this article: Solved: ArcGIS Monitor 2024.1 - Issue registering ArcGIS S... - Esri Community I haven't tried this yet.
For Datastore and Portal (Active-Passive)
I registered the 2 servers for Portal but only showing 1 under portal for arcgis.
Then when I tried to create  dataview I have no Health check option under identifier
JakeSkinner
Esri Esteemed Contributor
Hi @KikSiops I would recommend upgrading to ArcGIS Monitor 2025.  There have been several improvements with the latest release.
