We are seeing this warning message in the monitor/admin/logs"Failed to parse an arcsoc service name due to unexpected structure - cannot assign metric to service component"This is after upgrading Monitor Agent to 2026.1
I logged a support case and the support team was able to reproduce the issue. This issue has now been logged as a bug. https://my.esri.com/#/support/bugs/bugs?bugNumber=BUG-000186448
Yes I am seeing the same log entry for Monitor Server 2026.0 and Monitor Agent 2026.0.1
I'm not sure what it means yet.
I am seeing the same log entry as well for Monitor Server 2026.0
Hi @TomShewring, @DavidColey, and @MichaelOlkin1:Can you please contact Esri Tech Support and open a ticket?
Thanks, @DerekLaw - I'll open a support case.
@DerekLaw Hi, do you know when this bug will be fixed? Thanks
I am getting the same errors. @tomshewring did you find anything out?
Hi, no I haven't had an answer from ESRI
