when I try to register a new component my host in ArcGIS Monitor 2023 I get the following error message:New-CimSession : WinRM cannot process the request. The following error with error code 0x80090311 occurred when
and it won't let me register it.
I have done the solution in this link to enable permissions for wmi - cimv2 but without success:https://doc.arcgis.com/en/monitor/latest/get-started/linux/enable-permissions-for-wmi-cimv2.htm
Yes, I have been able to register the components of my Enterprise without problems.
Any other ideas?
Hi Emilio,
Can you please try adding the ArcGIS Monitor machine as a trusted host on the machine you are trying to register for monitoring? On that machine:
Set-Item WSMan:\localhost\Client\TrustedHosts -Value <machine>
Josh
please confirm, did you enable it per https://learn.microsoft.com/en-us/windows/win32/winrm/installation-and-configuration-for-windows-rem... ,
https://doc.arcgis.com/en/monitor/latest/get-started/windows/register-windows-hosts.htm
I am facing the same issues. Any update how to resolve it
It is possible that it is a problem of permissions of the main administrator of my machine or the administrator of the domain, after executing the command localhostClientTrustedHosts -Value in my <machine> PowerShell, I receive the error that I show in the image. I will talk to my IT team
I am also having the same issue after following all the steps mentioned above for one host, all others have been connected successfully.
Hey @EmilioTomeBlasco, did you ever figure out a resolution to this?
