Does ArcGIS Monitor 2025.0 Work with ArcGIS Enterprise 11.2
960
7
08-25-2025 11:53 AM
Evan_OKeefe
We’re planning to upgrade ArcGIS Monitor separate from our ArcGIS Enterprise environment. Currently, we run Enterprise 11.2, and will be for the next six months while we upgrade other systems.
Can anyone confirm whether ArcGIS Monitor 2025.0 is compatible with Enterprise 11.2?
Thank you!
DerekLaw
Esri Esteemed Contributor
Hi @Evan_OKeefe,
Yes, ArcGIS Monitor 2025 is compatible with ArcGIS Enterprise 10.9.x to 11.5, which includes 11.2. This means Monitor can register and collect metrics on components from these releases.
The only caveat is that ArcGIS Monitor 2025 needs to use the ArcGIS Enterprise 11.5 Web Adaptor if you want to deploy a reverse proxy for logging into Monitor.
Hope this helps,
CodyPatterson
MVP Regular Contributor
Hey @Evan_OKeefe
I can't seem to find any solid answer just yet, but I did find that at the bottom of the 2025.0 installation page it did mention 11.5 specifically, so the answer may be that it can only run on 11.5, but I'm not exactly confident so I'll continue looking, here is the page: https://doc.arcgis.com/en/monitor/latest/install/windows/arcgis-monitor-system-requirements.htm at the very bottom!
Cody
Evan_OKeefe
Thank you, Cody. I saw that too, which obviously puts the brakes on things, but I was really hoping that that wasn't the case.
DerekLaw
Hi @Evan_OKeefe,
Hope this helps,
CodyPatterson
Hey @DerekLaw
Would you be able to link the source for the information you provided? I had quite a bit of trouble finding that specifically, if this is internal to Esri only, would it be possible to create a documentation post with this?
Cody
Evan_OKeefe
@CodyPatterson I appreciate your help searching for this information.
Evan
DerekLaw
HI @CodyPatterson,
We don't have a "compatibility matrix" type document for ArcGIS Monitor and ArcGIS Enterprise releases - is that what you mean?
ArcGIS Monitor generally supports all releases of ArcGIS Enterprise that are in extended support or general availability.
Hope this helps,
Evan_OKeefe
Thank you so much, @DerekLaw. This is very helpful.
Evan
