Components in an Unknown state
771
11-29-2023 05:15 PM
FraserHand
I've got some components in an unknown state - they still appear to be collecting but are in an unknown state - what causes this - is there any way to bump them back to nominal.
Thanks
Tags (1)
GeoJosh
Hi Fraser. There's two scenarios that could cause this:
  • None of the metrics associated with the component have alerting enabled. The solution would be to enable alerting and set alert thresholds as needed on at least one associated metric.
  • There's an active incident that encompasses the components that is suppressing alerting. The solution would be to go to Administration > Incidents, find the offending incident, and enable "Alerting".GeoJosh_0-1701352888863.png
Josh
