We recently installed the Object Data Store on its own server, and installed the ArcGIS Monitor Agent on that server. It was usccessfully registered to the ArcGIS Monitor Server (2025.1) and shows up as a "Discovered component", but when we try to regiter it it with Monitor Server we get an error that the Object Data Store is not a current version. It is actually 11.5.
Hi @MichaelJenkins,
> Can Monitor 2025 monitor the Object Data Store?
ArcGIS Monitor 2025.0 does not currently support collecting metrics on the ArcGIS Object Data Store. Sorry. Right now, Monitor only supports collecting metrics from the ArcGIS relational Data Store. Please see this help topic, Register ArcGIS Data Store.
Please submit a feature enhancement request on the ArcGIS Monitor Ideas forum.
Hope this helps,
Hi @MichaelJenkins,
Hope this helps,
Hi @DerekLaw
I just installed ArcGIS Monitor 2025.1 with the 2025.1.1 Agent and I just wanted to confirm that you can still only get the basic info such as CPU and Memory Utilized from agents installed on Data Store machines?
Morten
Hi @M_O,
The metrics collected from ArcGIS Data Store components are listed in this help topic,
https://doc.arcgis.com/en/monitor/latest/get-started/windows/register-arcgis-data-store.htm#GUID-C4B...
Hope this helps,
