ArcGIS Server issue following patch install
1321
02-14-2024 02:01 PM
Dan_Brumm
I installed the 2023.3.1 patch successfully and without issue. Since the install I cannot connect to my ArcGIS Server? Nothing has changed, I am using the same account and URL to sign in.
1. When I try and log in, I get: An error occurred running the observer   Undefined is not a function
2.  Interestingly, I can still see my Server logs, but I can't get metrics or discover to work
Daniel Brumm
GIS Nerd
DerekLaw
Esri Esteemed Contributor
Hi @Dan_Brumm,
Can you please try the workaround posted by Josh described in this thread:
https://community.esri.com/t5/arcgis-monitor-questions/monitor-broken-after-2023-3-1-install/m-p/137...
I believe it should resolve your issue.
Hope this helps,
DerekLaw
Hi @Dan_Brumm,
Hope this helps,
Dan_Brumm
That was it! I had 6 reports named with all numbers. Deleting them cleared up the error.
Thanks.
Daniel Brumm
GIS Nerd
