ArcGIS Monitor Notification Email
5311
17
03-23-2023 07:50 AM
SteveMcCarthy
Where would you go to update name field so it shows the Name associated with the ID?  Is it possible to change what attributes are in the notification?
LisaDong
Esri Alum
Heads up everyone,
For your reference, here are the two enhancements that helps with this behavior:
  1. ENH-000159627 : For email notifications in ArcGIS Monitor 2023, provide equivalent functionality to ArcGIS Monitor 10.8.1.
    • Status: In Product Plan
    • In ArcGIS Monitor 2023.x, the client is asking for Metric Name to be populated instead of NA, along with STATUS, ALERT RULE and ALERT VALUE information in email notifications to restore equivalency with ArcGIS Monitor 10.8.1.
  2. ENH-000153088 : Ability to create a summary email template within ArcGIS Monitor.
    • Request to receive periodic summary of issues via email templates.
DerekLaw
Esri Esteemed Contributor
Hi @SteveMcCarthy
Currently, it is not possibe to customize emails sent from notifications. However, we do have the enhancement of being able to "customize notification emails" on the ArcGIS Monitor Dev roadmap. We are working on enabling this in a future release.
Hope this helps,
WhereMatters
This is a must-have feature for Monitor 2023. Currently, email notifications are not useful at all. Why do you have to click a link to see the alert? The email notifications at 10.8.1 were so much better, they told you at a glance, exactly what was the alert all about.
René_Ténière
I take it the ID refers to the actively running metric? For instance the email sends as ID: 2, which in the list is labeled as Name: Process CPU Utilized - postgres.exe (%). It would be excellent if instead of NA in the email Name field it could insert the label Name of the metric...
arahman_mdmajid
@DerekLaw
We recently upgraded to 2023.1 version and the notification still does not show the name and appears as NA
Kindly look into it as its very critical to respond to production components and compared to test/dev components based on the email we receive.
Abdur Rahman
GIS Developer
Amanda__Huber
MVP Regular Contributor
We'd like to add to this request as well. We're happy to see the LINK take us directly to the issue (yay this is an improvement from the old monitor era) but overall this email is not a useful for administrators.
ID numbers and Name as NA is not helpful. Please consider implementing this update sooner than later.
thank you,
Amanda Huber
René_Ténière
We have been fighting this battle for a while now... Here was my suggestion:
Here is an overview of the issue, possible fix, and comments from users:
The enhancement request for “provide the ability to customize emails sent from notifications” doesn’t correspond with the problem with 2023.1.  The emails sent by 10.8 included useful information without any customization on our part.  We expected to have such basic functionality working in the new version.  We imagine “customization of emails” to include things like setting letterheads, fonts, etc.  In other words a complicated request that isn’t high priority.  That’s not needed by us if the functionality from 10.8 could be revived.
Yes, it appears to be either a mistake, an oversight or something they figure to fix down the road.
At the moment, 2023 isn’t usable in my opinion.
I’m beginning to wonder if one of the third party alternatives isn’t cheaper and better
The 10.8.1 Monitor notifications included:
Level
Name
Type
Counter
Value
Rule
Validation Value
Last Updated
Notes
Info
monitor.server.ca
SYSTEM
Disk % Idle ( E )
1.00
10
Jun 27 2023 23:01:19
Disk is busy
The 2023.x notification contains the following information:
The Email Subject Line – Collection Name
The following table is included in the email whereby NAME field references the Metric Name, only it says NA but as seen in the screenshot below it should state Request Response Time Max (s). STATUS field indicates the alert threshold, which was Warning, however, the ALERT RULE and ALERT VALUE should be listed as AVG >= and 3 s respectively.
ID
NAME
STATUS
URL
26
NA
Warning
LINK
At a minimum the new notification table with the existing information available (ID is useless and could be dropped) should be:
ID
COLLECTION NAME
METRIC NAME
STATUS
ALERT RULE
ALERT VALUE
URL
26
SERVERNAME: ArcGIS Server
Warning
AVG >=
3 s
LINK
As you can see, the notification email collects the information from the collection metrics whereby alerting is set to on:
Amanda__Huber
To add to this, I did more testing with the webhook functionality and it also is just as limited. This is disappointing. Here's a sample from the call (below) nothing shows the Server Name or Metric Name/Error Name only the code (similar to the emails):
info
id
name
Enterprise Server Infrastructure Notification
monitor_url
https://APP-G......../arcgis
version
2023.1.0
sent_at
1688140812194
trace_id
f74xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
events
operation
update
resource
alerts
occurred_at
1688140810386
attributes
id
454
created_at
2023-06-30T15:55:10.669325+00:00
opened_at
2023-06-30T15:51:33+00:00
closed_at
2023-06-30T15:56:33+00:00
metric_id
41
observer_id
component_id
77
state
resolved
status
aggregation
avg
operator
samples
info_threshold
warning_threshold
critical_threshold
6
querystring
Here is the actual error on our server and server name:
@DerekLaw is there any timeline for when this will be resolved/implemented?
Thanks
DerekLaw
Hi @Amanda__Huber,
> ... is there any timeline for when this will be resolved/implemented?
Sorry, I don't have an estimate of when this will be implemented.
Galada_321
@DerekLaw  Is aforementioned issue resolved in ArcGIS Monintor 2023.2?
