ArcGIS Monitor Fails to Register ArcGIS SpatioTemporal Data Store Component
1113
5
04-15-2025 04:45 PM
dimesv
Hi guys,
I have installed an ArcGIS Monitor Agent on the ArcGIS Data Store spatiotemporal virtual machine and have login to ArcGIS Monitor and am trying to register the component.
I have obtained the username and password using the command line listadminusers but keep getting the following error when registering the component:
Cannot read properties of undefined (reading 'db.port')
Any ideas on how to fix this?
Jose De Sousa
Esri NZ
DerekLaw
Esri Esteemed Contributor
Hi @dimesv,.
ArcGIS Monitor does not support collecting metrics on the ArcGIS spatiotemporal Data Store. It only supports collecting metrics on the ArcGIS relational Data Store.
See help topic, Register ArcGIS Data Store
Hope this helps,
DerekLaw
Hi @dimesv,.
Hope this helps,
dimesv
Thanks Derek for your prompt reply.
Cheers,
Jose
HarunJoeVellikkara
Hey @DerekLaw ! Good day
Is this true for TileCache Datastore as well coz I see the same error as above
DerekLaw
Hi @HarunJoeVellikkara
Currently ArcGIS Monitor only supports collecting metrics on the ArcGIS Data Store (relational). It does not support the TileCache Data Store. Sorry.
Please post a feature enhancement on the ArcGIS Monitor Ideas forum
Hope this helps,
HarunJoeVellikkara
Noted! Thanks for the prompt response @DerekLaw
