ArcGIS Monitor 2023 to ArcGIS Dashboard.
1590
09-28-2023 08:51 AM
TarigAhmedmemphistngovAhmed
 ArcGIS Monitor 2023
How can I get the same serial charts that are in ArcGIS Monitor to ArcGIS Dashboard?
DerekLaw
Esri Esteemed Contributor
Hi @TarigAhmedmemphistngovAhmed,
Aggregate components into a collection. When you define the collection, select the option to enable a feature service. After the collection is created, you will also get a REST endpoint - this is the feature service you enabled. Next, you can register this as a new item in an enterprise portal, this creates a new feature layer based on the feature service. Then you can add that feature layer to ArcGIS Dashboards.
Please review this help topic Collection feature service schema
Hope this helps,
DerekLaw
Hope this helps,
