ArcGIS Monitor 2023.2 - No option to add Datastore as component
317
06-04-2025 11:21 PM
KikSiops
I cannot see ArcGIS Datastore when I tried to register a component. Is this a limitation to this version?
If it is, any suggestions how to monitor our Datastore health? We are on HA environment  and Enterprise version 11.3
Thank you!
StevenBeothy
The capability to monitor the ArcGIS Data Store (Relational) was introduced at ArcGIS Monitor 2024.1 and fixed with a patch at 2024.1.1.
See the Help and this Blog posting for more info.
With the ArcGIS Monitor 2024.1 release, administrators can now register the relational ArcGIS Data Store as a new component and collect metrics.
It is possible to still register your Relational datastore with the older ArcGIS Monitor 2023.x releases by following similar steps as this YouTube video. But considering your release of ArcGIS Monitor 2023.2 has been retired by Esri since December 15, 2024, it would be recommended to upgrade to a supported release and get the new functionality that comes with it.
MarcoBoeringa
Since this other thread about ArcGIS Monitor suggests the Datastore and associated database is just a regular PostgreSQL installation, the logical option to monitor your Datastore health would be any of the available (commercial) software packages for monitoring PostgreSQL database health.
E.g. pgAdmin would be a logical choice. DBeaver is another option, and there others out there if you do a bit of searching. Although both of these suggested options are more about database management, and not so much about alerting or warning you when something catastrophic is about to happen. There are other options out there though, that do more of a kind of monitoring job if you do a bit of internet searching.
StevenBeothy
KikSiops
thank you @StevenBeothy
