ArcGIS Monitor 10.7 forward compatibility
826
01-13-2022 09:31 AM
forestknutsen1
Is ArcGIS Monitor 10.7 compatible with Portal 10.8?
ReeseFacendini
Esri Alum
ArcGIS Monitor 10.7 should work with Enterprise 10.8 because the connections are made using the REST API.  It's recommended to keep all Enterprise software (which includes ArcGIS Monitor) at the same level to reduce any potential issues of incompatibility.
ReeseFacendini
Esri Alum
