Analysis Doesn't Display < 2 Hours of Stats
1878
07-21-2023 07:19 AM
RyanUthoff
MVP Regular Contributor
I recently created an analysis and it's been working great this week, until suddenly today. I noticed all my serial charts that should contain data on four different servers only contains either zero or one server. However, this is only an issue when viewing the past 2 hours or less. If I move the time out to 6 hours or more, I can see all four servers.
I thought maybe the Monitor stopped logging in the past 2 hours, but I can see the stats fine on the individual component page within Monitor up to within a few minutes ago. Furthermore, when selecting the last 6+ hours, I can see server stats for the last 5 minutes for all 4 servers. Yet, when I switch the analysis to the last 2 hours, it sometimes displays no servers, or 1 server. It's random when I refresh the page. I attached a couple screenshots as an example.
I was wondering if anyone had any insight to this issue before I submit a support case. Thank you!
GeoJosh
Ryan, can you try combining the "ID equals" rules into one by using the "is any of" operator?
GeoJosh
Hi Ryan, can you share screenshots of the data expression and chart configuration settings for the graphs that you're seeing this behavior on?
RyanUthoff
Sure thing! I pretty much copied it exactly from the sample analysis that was provided with Monitor (which is working fine). The only thing I added was explicitly defining four of my components in the data expression. Otherwise, it should be an exact copy from the sample analysis.
GeoJosh
RyanUthoff
Ah, yes, changing it to that seemed to have fixed it! Now my graph is showing again when selecting a time frame of 2 hours or less. Thank you!
